I know they have “wheel bearing grease” but that doesn’t mean it’s the only or best now..What grease do you use? We use a lot of high temp grease. Going on a long trip with the trailer and thought I should repack the bearings. Any grease is better than no grease.
Red is rated for wheel bearings....some tubes specify that fact. I use red on everything since its a water resistant, high temp grease.What grease do you use? We use a lot of high temp grease. Going on a long trip with the trailer and thought I should repack the bearings. Any grease is better than no grease.
I bought a whole barrel of graphite grease at an auction many decades ago. I just sucked it up in to the grease gun and used it. That led to several years of bearing failures. The barrel has been sitting in the corner of the shop for over 40 years now. I'd give it away, but then I'd have to find another place to pile all the junk that's on top of it.In my innocent youth I used black graphite grease on bearings .
I only found out years later that I shouldn't have , and yet no bearings I ever packed with it overheated or failed . I would have to agree , any grease is probably better than none .
I think graphite grease is for sliding surfaces......on wheel bearings, I think it's so slick that the balls don't rotate like designed....they just slide along and wear a flat spot on the "rolling" portion (balls/rollers) of the bearing.I bought a whole barrel of graphite grease at an auction many decades ago. I just sucked it up in to the grease gun and used it. That led to several years of bearing failures. The barrel has been sitting in the corner of the shop for over 40 years now. I'd give it away, but then I'd have to find another place to pile all the junk that's on top of it.
Ya, I think it's for 5th wheel plates and what not.I think graphite grease is for sliding surfaces......on wheel bearings, I think it's so slick that the balls don't rotate like designed....they just slide along and wear a flat spot on the "rolling" portion (balls/rollers) of the bearing.
I remember that long fiber WB grease was the norm when I was a teen. When the industry went to a common grease for joints and WBs, I was skeptical at first.....a new experience for me.In 1970 the place I worked for tossed out a 10 pound can of Standard Oil wheel bearing grease because it wasn't full and the can was beat up. I fished it out of the trash skimmed off the top layer and have been packing wheel bearing with it ever since. It's a long fiber heavy grease and yes, I still pack with the palm of my hand.
You are entitled to your opinion, and I to mine!Pretty much any grease having a National Lubricating Grease Institute (NLGI) rating "GC-LB" (chassis and wheel bearings respectively) should meet the need. Neither color nor additives -- graphite, "moly", PTFE and so forth -- are deciding factors.
