Green Diamond 214 engine.
In a 1947 KB PU.
Oil pump is leaking when running. It not bad but it needs fixed. In the process of restoring the PU.
I have been told that when this is removed the engine needs to be retimed as both run off the same cam gear.
Looking if someone would have literature showing how it is removed and taken apart then retimed if needed.
Thank you.
