jerrymann
My GIHL mounted Wr204 finger wheel rake digs up green grass into the dry hay that i bale. I have tried adjusting height, but it's not picking up the material or digging up junk. Is this a problem to the rake or what am i not seeing?
It's been awhile since I had one, but you don't use the 3-point to adjust the teeth, you move the big tension spring. I forget the exact procedure.
You set the frame height to a certain height. Then adjust the spring tension to how much pressure you want on the rake teeth to the ground. There is an operators manual on Ebay right now for $13. It would show you how to adjust the rake. Also the three point mounted wheel rakes did not do a very good job in uneven ground. They did not work the best on flat ground. That is why they sell cheap.
