would also, ask, what does 'burnt' mean? They are switching current & will not remain mirror like in finish. Still run?(quoted from post at 10:47:32 05/06/14) It's not simple to test condensers, so try another one. Even an old one you kept (of course) when you put on a new one is a good choice.
o current with screwdriver touched from stationary structure to movable arm of points (not contact itself, but arm structure)?(quoted from post at 11:10:57 05/06/14)
They have a charred appearance and don't switch current, even manually with a screw driver.
n that case, I do not think it is a burned points issue. Since you can't even get current by shorting the arm up stream of actual contacts, then it isn't the contacts, but rather you have lost continuity up stream. A likely point is the copper strip from feed-thru to points or a shorted insulator in the feed-thru itself.(quoted from post at 12:11:31 05/06/14) Yes...
eep moving upstream then. Remove the wire between coil & distributor & strike a ground to that coil terminal & see if you can see a spark. How about voltage input to coil's other terminal?(quoted from post at 13:18:40 05/06/14) Can't be the copper strip or insulator
because I bypassed that and still nothing.
o questioning John as a great source, but this fellow hasn't found the problem yet. Too early to buy a distributor when he might need a crimp terminal or an ign switch!(quoted from post at 17:59:29 05/06/14) Codi, Check with John Smith he may have a good
side mount distributor. I just bought one from
him a few weeks ago and it was like new. He is a
good man to deal with. James
(quoted from post at 01:15:27 05/07/14) Codi,
Systematically trouble shoot it as JMOR suggests. You are in good hands.
K, so now you have another problem & need a new thread/subject.(quoted from post at 21:18:13 05/06/14)(quoted from post at 01:15:27 05/07/14) Codi,
Everything was getting voltage so I just cleaned the points really good and it fired up. Still dealing with the sputter though. It is not in the wiring or the carb. and I adjusted the valves. Still has the sputter. I did notice that it runs better with only cylinders 2,3,4 running than when I add 1 back in. Curiouser and curiouser...
