guidance system problem
gbs
I have an EZ250 with a ag15 antenna that's about 2 years old that gets off track, according to the spec's on this unit it should be able to operate equipment by itself, even when I first got it I wasn't really impressed with it because I would lay off a straight line for it reference as i am using the AB setting and by the time i made a dozen passes my trails looked like a rocking chair rocker,now not only does it crook them, according to the paint marker it's vearing off the coverage width, i have stepped off a couple places it showed to be missing and it was, I've check the settings and from what I understand they are correct with the exception of the last update mine is 3.00 the new one is 3.10 could this be my problem or am i doing something wrong,I used the neighbors light bar before buying this unit it took a little getting use too but once I figured out that the light bar was a general reference and quit try to keep the lights centered it worked good.
Try driving by just the paint, and see if it is right. If it is you have 3 choices drive by the paint till it quits or send in to have fixed, or junk it.
It sounds like you have it set on "curve" guidance and not "Straight AB." You should have a screen full of perfectly parallel lines, not rocking chairs.
What are you useing it for?? Spraying and spreading i find ours works good. Tryed planting with it year befor last and after about an hr it was out by about 4ft. Still going straight but the ab line was out. Ours would be nearly 3yr old and havent updated it yet.
