Good afternoon. I recently replaced the front countershaft seal in my '41 H. When doing so, I also discovered slop in the front countershaft bearing. I could not get the bearing out without removing the countershaft, so I ended up removing the clutch shaft, input pinion assembly, & transmission output shaft to get at it. All the original parts & shims were re-installed except for the front countershaft ball bearing, which I replaced with a NOS Greene bearing of equivalent specification to the IH original.
Two differences since doing this work:
1) The transmission makes more noise than before. This noise varies with engine speed but not gear, which is consistent with input pinion noise. It increases when the tractor is under load. I suspect that the new bearing has tightened up the clearance between the input pinion and countershaft, and that after 80 years the wear pattern of the gears adapted to the old bearing, and the noise is therefore normal. I would appreciate any insight on this. Should I look for a deeper problem?
2) The clutch is sticky. When driving along, if I step on the clutch, the tractor continues to drive for a few more seconds before the clutch releases. When shifting gears I notice significantly more grinding than before, like the input shaft is not slowing down after stepping on the clutch. I can wait to shift gears, but the 2-3 seconds of additional driving when stepping on the clutch needs to be corrected. Is this a binding clutch pilot bearing? Any thoughts on this would be appreciated.
Thanks in advance for any thoughts on the transmission noise and clutch problem.
Dave
Dave
