H D T V Need Help
Don't know what side channel thing is. Tower would only help if you have obstacles to clear. Ours was about half way up our tower. About two years later they had to move it up higher to clear trees.
Around here it's common to see them in front yards on 4-5ft poles. Your main thing is a clear path and a stout pole so it doesn't sway with the wind.
I'm Thinking WILSON is Talking about the Extra "Digital Channels" that a We can supposedly receive that are transmitted by One TV Station, I've heard about three Per Station say Ch 2, I'm not completely clear on it Myself yet. Larry KF4LKU
I've had an HD tv for over a year, and I don't have cable...just an antenna on a 20-foot tower.
Here in the Louisville, KY area, I can get NBC on channel 3-1, which is the same as analog channel 3...but I also get 3-2, which is 24-hour weather. Channel 3 also broadcasts a carrier signal on 3-3, but the music videos they used to carry are no longer aired there.
ABC Channel 11 only broadcasts the main signal. KET, the PBS outlet, has 15-1, which is the same as analog channel 15; 15-2, which is the same as analog channel 68; 15-3, which is regional educational programming; and 15-4, which is mostly GED education programming. Then there's channel 21-1 thru 21-4, which is primarily religious in nature. CBS channel 32 and FOX channel 41 only have the main channel, as is the case with independedt channel 58...and KET-2 is boradcast on channel 68 and has the same content as channel 15-2.
I can tell when a program is being broadcast in HD as opposed to being an analog program on an HD channel: the HD programs fill the full width of the screen, while the analog programs have a 1-1/2"-2" black "border" on the sides.
If you're on channel 3-1 and hit the "channel up" button on the remote, it moves to channel 3-2,rather than going to channel 11, as it would on an analog set. Also, when manually entering a channel choice, you must enter ALL the digits, beginning with a zero. Channel 3-1 must be entered as "0031"; channel 32-1 becomes "0321" when you manually select it.
It ain't rocket science, but it does take some getting used to.
I've been trying to find someplace to find answers about the change over. obviously, the people in charge dont know what its like to live in the country, and have no tv when the weather is bad.
It is sorta confusing, but maybe I can translate some.
For starters, check out this page.
www.dtv2009.gov
Thats where you can sign up to get coupons for a free converter box for your TV.
They are going to stop broadcasting in analog in February, and instead only use digital broadcasts. What that means is that you need either a new HDTV, or one of the digital converter boxes.
You hook up the converter box, and that will use an antenna to get the signals, which has the 13-1 and 13-2 stuff that Buzzman mentioned.
Lots of stations already use the digital broadcasting, but not all of them do yet. That might lead to some troubles for those of us trying to switch early. I will say that depending on where you live, the "rabbit ears" antennas might not work so well anymore, and you may have to go buy a new antenna.
Does that help at all, or just make things clear as mud?
