H delay lift?
sgtbull
Is one of the three available ports "delayed"? (I'd guess to raise rear culitivator rigs after the front) If so, which one is delayed?
Yes, the one that is offset from the other two. Two are directly in line and one is not. It is that one.
Slater is correct. This subject has been gone over a thousand times. All lift ports come from same source. The rear one is a delayed drop as you have to push lever farther forward to release the check valve that holds load up and it takes a trained hand to get the feel of that.
Dave and Pete are correct, no delayed lift on the rear unless the delay valve is screwed in. I have even seen the rear section begin to lift first, so the pressure distribution is not exactly uniform.
thanks for the replies.. it had been a while since I had one apart, but I was thinking they shared a common "manifold"
