h farmall distributor
I would buy a used one. Most of the time they are OK, If not you may be able to make one out of two. Steel Wheel Ranch is a good place to start.
(quoted from post at 13:47:17 04/28/10) does anyone know where to get a rebuild kit or parts for the distributor on an h?
If you want to spend the money, I can get you a brand new distributor, complete with the electronic ignition built right in.
i guess if i have to i will have to get a new or good used one. but was hopeing to find a source for the bushings and possibly a shaft.
(quoted from post at 04:59:55 04/29/10) i guess if i have to i will have to get a new or good used one. but was hopeing to find a source for the bushings and possibly a shaft.
The shaft is readily available, but I do not have a source for the bushings.
