H farmall Hydralics
Anonymous-0
I've got a 1945 H that i just put a model 31 ih loader on it got it up and working used it for about 3 hrs and leaking fluid out the belley of tractor.what all is involved to fix this problem? leaking so bad after using it for that long it will only lift bucket up about two feet off the ground.
The belly pump has a single seal at the input shaft. Remove the pipe fitting /elbows from three ports. Remove the control rod lever. Remove the cap from reservoir. Drain fluid from bottom. Remove drive shaft (two cotter pins) With a floor jack, or three people (heavy and awkward) remove the pump/res from belly.
Remove pump from res. Stick a flat bar in the pump gears through the intake port. Remove the drive coupling (lefty loosy normal threads) pull seal- buy new -replace seal, put back pump, put back unit etc. 3 hrs. JimN
