H John Deere
I was able to remove the seals in the transmission housing with a lady foot backed up by a short flat bar of steel. I removed the outer seal in the axel housing with a long bar of steel after removing the axel. The seals are still available from John Deere. They are a press fit.
Make sure you spray a little lubricant on the retainer as well to loosen it up. I did the same thing on mine and went around the retainer prying lightly. The seal in the tractor is thick and takes a little more effort,but will come out easier doing the around the hole idea. I just bought new seals from NAPA (CR 32501) and installed them in my H.They are $29.43 each.
