H trans input and countershaft seal
Dan Wittek
Hey guys. Any ideas on how to remove the transmission input yolk so I can access the seal? I have tried pry bars and tapping on the yolk with a hammer. No luck yet. Also... the countershaft seal is leaking. No bolt in the center of the countershaft yolk. How does it remove? Sorry if these are basic quesions. My service manual does not give this detail, nor could I find it in any previous posts. I have the new seals and am ready to rock if I could just get it apart! Please see my picture of what I am looking at if needed. THANKS!
I'll try loading this picture again.
You have the bolt and washer removed. Good. Now put the clutch shaft (minus the wavy coupler) back up there. Place a shallow socket - I use a 1/2" drive 3/4" - between the two yoke pieces and a pair of 3/8" bolts and flat washers to pull the stuck half from the input shaft. Tighten the bolts evenly and be careful not to damage the tapered holes in the yokes.
For the countershaft, , basically it is apply the brakes and lock them, transmission in first or reverse gear, and block the rear wheels. Use a LONG bar or wrench, get on your back under the tractor, put your feet against the wrench and get your back up against the right rear tire and PUSH.
I'm a bit fuzzy on the yoke. I think it slides out after you remove that center bolt.
The countershaft coupling is threaded on the shaft. Right hand threads. So you have to block the shaft from turning somehow and get some leverage on it to break it loose. One trick is to put the PTO in gear and then lock the PTO shaft. I use an old PTO yoke with a bar though it.
