42FarmallMatt
Hey Gang, while waiting for magneto parts for my JD A I'm back getting things cleaned up on the Farmall H to put the motor back together this fall once temperatures cool down. Was cleaning the thermostat housing and water pump today and was curious about how do I know if my water pump is good or if it needs to be gone through and re-done. Took the packing nut out and noticed the previous packing had deteriorated but the shaft and impeller itself was in good shape with no play and my pulleys were turning good with no play either. I don't recall having any leaks for the short time this thing ran several years ago. Pumped some grease into both zerks at the top and bottom. Top pushed out a little bit of mud which I can only assume is corrosion from her sitting for a while and grease got to the bottom without much discoloration but I welcome any input.
