RWS904
- Location
- Northeast Florida
I got what I believe to be a 1949 8N on trade from a friend of mine recently (engine ser. no. 8N238065). He said it hadn't been running for a
couple years, the clutch was rough, brakes were shot and needed other work that he couldn't recall. I couldn't pass it up despite the eye rolling
from my wife. It's been converted to 12V and came with the original generator in a box with other spare parts.
After reworking the distributor, changing the plugs, and overhauling the carb, she fired right up and runs surprisingly well. I went to adjust the
clutch and found it looks like the 2N/9N setup with an eyebolt, not a clevis. The clutch sticks when cold and is hard to get in gear initially,
but shifts normally after driving it for a few minutes. Not a major cause for concern at the moment, maybe it will be later.
The right rear brake drum was coated with grime, after cleaning it up and changing the hydraulic fluid, it leaks like a sieve. I noticed the
right axle shaft had a two piece squeeze nut that was so badly stripped I could just pull it off the shaft by hand without turning. I guess
it's safe to say that at a minimum I need a new shaft, hub, bearing, etc, etc. I ordered an extensive shop manual collection and will start
looking into what I need to do to replace the shaft. The threads look so bad that I can't imagine it will be possible to salvage it or simply
replace the nut with any hope of it tightening down.
The other oddity (that he warned me about) was that this particular unit only had draft control, and not the position control lever when he bought
it years ago. He threw in an extra top cover he bought off of Ebay with the position control lever, but I haven't really looked it over yet.
Right now, I'm just happy to have her and looking forward to an ongoing project. I'll post pictures at some point of what may be a mutt, but she
is beautiful to me!
is beautiful to me!
