(quoted from post at 17:07:27 01/22/19) I bought a cheap one from HF. It got a lot of scale off a tri-axle trailer before sanding blasting. Worked Ok, sure saved time on sandblasting. Just lasted long enough to do the job. I figured it was just a throw tool but got the job done.
(quoted from post at 16:25:00 01/22/19) SVcummins; A few years back when I had access to the welding shop at the local community college I did a side by side comparison of the Harbor Freight needle scaler I had recently purchased and the American made one owned by the college. That one was probably an Ingersoll Rand, but I can't remember for sure. Using the same air source and working on the same weld scale or rusty part, the shop's tool was better. It had more power at every setting than the Harbor Freight tool at its equivalent setting. I also used both tools on the surface of a brightly polished piece of steel plate. This was a technique I had done a lot of on art pieces to create a softer, stippled look. The Harbor Freight scaler produced a much lighter texture---too faint for my purposes, in fact. I wanted the Harbor Freight tool to be just as good as the American made one so I could do what I wanted with it at home, but it wasn't. It had less force using the same air supply, and I thought the steel of the needles seemed softer than the needles of the American made tool.
Stan
