hard start briggs twin
Most likely your MAGNETRON coil is being affected by the heat. This happens when the engine get between 5 and 10 years old. Replacement is the only fix.
Kent
In addition to what kent said to check,if eng an ohv,check valve clearances,valves may need an adj & when eng hot clearances may be excessive.
I also think its your magnetron coil. Hal
Depends on mod of eng,opposed twin has dual coil on a single armature,intek & vanguard v twins use a seperate coil/armature for each cyl.
