hard starting 2350
oldiron48
I have a JD 2350 and have trouble starting it,if you just start it the starter just bearly will turn it over,if you turn the steering wheel back and fourth it starts easy, any help would be great.
If battery ground cable is still factory attached to batt box I'd suggest relocating it to a starter mounting bolt.
14 - PUMP COVER AND VALVES MODEL NO. 34PP1 40 CM3 (2.4 IN3)
AR33249 SCREW,HYD PUMP SHUT-OFF,ASSMY/FIELD ADD 15.48
4 - HYDRAULIC PUMP 23CM3 (1.4 IN3)
AR38225 HYDRAULIC PUMP, HYD PUMP SHUT OFF A ADD 32.03
USD
