hard to shift
There are a lot of very knowledgeable people here, but none of them are mind readers. What make and model is your tractor????
its a farmall B when I fist start it its hard get it in first I it might be the pressure plate can you tell me were it is on the tractor?
Ok so it is an IH B so what are the symptoms? Just slow to stop so it will go into gear cold stiff oil will not go into gear with clutch pushed out may need adjustment. If sticking as you use it may be some dry or rusty shaft and hub in clutch or disc rusted to plate or flywheel.
This is all just behind the engine between the transmission and the engine. So now you see why the more informatin you can give the more we can help. No insult or criticism intended.
When you first put your foot on the clutch pedal, there should be about 1/2 - 3/4 inch of "free play".
That is an area of pedal travel right at the top before the release bearing applies force to the pressure plate fingers.
If there is more than an inch or so, the linkage needs to be adjusted.
If that is good, and the clutch is still dragging, could be the pilot bearing is frozen, transferring power to the transmission even when the clutch is released.
It could also be a warped clutch disc, or a failing pressure plate, especially if the clutch is jerky when easing it in.
The engine also needs to be at slow idle when shifting. That transmission has no synchronizers, so it will grind if shifted while spinning. Also be sure the oil in the transmission is up to the full level. The oil helps slow the transmission when the clutch is released.
Not sure about a B but H and M have a zerk in the fly wheel you can see from the bottom side, hole in bell housing.
Pete
(quoted from post at 11:44:18 06/24/19) its a farmall B when I fist start it its hard get it in first I it might be the pressure plate can you tell me were it is on the tractor?
Newr, what makes you think that it is the pressure plate?? you can post as many words as you want. There is no charge.
(quoted from post at 04:18:33 06/25/19)
LOL!
Just wondering: Would extra thick oil have anything to do with initial hard shifting? Then it warms up and gets easier?
I was just told that by someone that lives up there besides that I don't no,do you no what may cause it to be hard to shift or any ideas at first like I said earlier once I get going it shifts good.
This isn?t a fix for your problem but, if you are sitting
on the tractor, with your foot on the clutch, and the
tractor in gear before you start it, does the clutch
fully disengage the transmission, or will the tractor
creep forward as the starter turns the engine over?
I?d say if it creeps forward, it is time to split the
tractor and do the clutch. If it doesn?t creep forward,
starts and runs fine, and you can shift to other gears
while the engine is running, I?d say live with it till you
have time or money to allow you to tear into this
tractor. Too me , it sounds like components of the
clutch are worn, and complete clutch failure could
be just around the corner. Grinding of gears while
clutch is depressed is often the throw out bearing,
and can also be the fingers on the pressure plate
assembly were the bearing makes contact. Only
way to know is by taking it apart. Our old 35
Cockshutt would eat a throw out bearing every three
years when dad used it on his AC Roto Baler. Not a
hard job to change. Just my thoughts.
(quoted from post at 08:30:59 06/25/19) okay thanks I think your probably right about just live with it
What's your history with the tractor--just buy it or you've had it for some time? Might have had hidden issues when it came to you.
I bought it like 15 years ago it just started being hard to shift when you start it maybe at a year ago it may of had past problems,its over 50 years old so it will start having problems.mostly just use it to pull a shedder
