Hauling Advice Please (trailer, etc)
Neddy191
I have a 53 Farmall Super H (narrow front) that I'm looking to haul to tractor shows/parades/rides 5-6 times a year. I doubt I'd ever go over 50 miles one way for one of these trips. I have a 2010 Ford Expedition with towing package rated up to 8900 pounds. I'd be using a weight distributing hitch.
What type of trailer would be best for me? I think my tractor is 4000-4500# range. There is a trailer manufacturer (Kaufman) not far from me so I have looked a little at their trailers. I was thinking about a 20' 10000 gwvr utility trailer with heavy duty fold down rear ramp.
If you don't plan on hauling anything heavier, you don't need that big
of a trailer. A car trailer with 3500lb axles will easy handle a SH.
Good point, 10,000 is way more than I need. I'll probably go for the 8,000lb model though, I'd rather have a little more than I need in case I end up getting something bigger down the road.
If you ever buy an M or a 400 or 450 basically anything heavier than an H you will NEED the 10000 lbs trailer. The weight that it is rated for INCLUDES the weight of the trailer itself. Therefore, if the trailer weighs 2000 lbs and the H weighs 5000 lbs you are at 7000lbs. Do yourself a long term favor and get the heavier trailer.
(quoted from post at 12:53:36 08/14/15) If you ever buy an M or a 400 or 450 basically anything heavier than an H you will NEED the 10000 lbs trailer. The weight that it is rated for INCLUDES the weight of the trailer itself. Therefore, if the trailer weighs 2000 lbs and the H weighs 5000 lbs you are at 7000lbs. Do yourself a long term favor and get the heavier trailer.
H does not weight 5000 lbs....
But he's otherwise correct. I would say go for the 10,000 lbs gvw trailer, so long as your rig can handle it ok and you have the budget for it. Who knows, maybe you'll get an interest in tractor pulling. If that happens you'll need weights for it.
Way too much trailer for that suv. I'd suggest 16' with 3500 lb axles. Keep the brakes working on that trailer and load your tractor in the right spot, don't get too heavy on the front or back.
Tractor data shows the minimum weight for the super H at 3875 pounds.
16 foot trailer with 3,500 pound axles if heavy built weighs about 2,500 (have had mine on the scales).
This would make the total weight of trailer and load at 6,345 pounds. That is getting very close to the max load capacity of the trailer.
Doable yes but I never like to get that close.
As I haul tractors and other stuff on a pretty regular basis my suggestion would be to get an 18-20 foot with the 5,000 pound axles allowing the trailer to haul 10K pounds.
Cost is usually not that much difference and you are not maxing out the trailer with your current tractor.
You will find that if you buy a trailer with to light capacity you will regret it and the extra capacity will come in handy at time.
In regards to towing both will tow about the same behind your vehicle and like has been mentioned have a brake controller installed in your vehicle and keep the brakes on the trailer in good working order and you will be fine.
Just be aware that having brakes on trailer does not mean that you can stop on a dime so you must allow for more stopping distance.
Currently I tow a 16 foot with 5,200 pound axles, a 18 foot with 3,500 pound axles and a 18 foot goose neck with 7k axles all with brakes.
I like the goose neck the best as it is easier to turn around in tight spots and I find it easier to chain and boom down the tractors.
One thing to keep in mind that when chaining down tractors (don't like straps) that the booms and chains cannot come out past the rub rail on a goose neck or past the fenders. DOT will ticket you quick if they see that.
I use ratchet booms as I find them easier to use. Others will disagree on the ratchet booms, but I have hauled tractors from MO as far away as NC and CO with no problems.
Just my 2 cents
(quoted from post at 08:14:59 08/19/15) Tractor data shows the minimum weight for the super H at 3875 pounds.
Just my 2 cents
RB, last time this was discussed, which was very recently there was some good information WRT the rub rail (no tickets)
Showcrop
I must have missed that one. Also varies from state to state from what I have been told by truck drivers.
I am always open to learning. The more we know the better.
(quoted from post at 14:07:52 08/19/15) Showcrop
It was only about 2-3 weeks ago so it shouldn't be hard to find.
(quoted from post at 12:40:17 08/19/15)
Just my 2 cents
I've done it both ways. Sometimes you have to go with what works. I've never been stopped by the D.O.T., but I have been scrutinized thoroughly.
