1956 chevy
got a question about hauling equipment. I just got 2 hay bailer disk mower and hay wagon,, can i haul the equipment be pulled on the hay wagon i live 2 hours away how fast can a hay wagon be pulled. thanks for the help.Ray
Yeah......I think a 2 hour drive may turn out to be significantly longer.Depends on how good your running gear is. I've pulled some at 60 mph, others take up 2 lanes at 15 mph. YMMV.
The wagon would fit on most car trailers, unless it has tall sides. Strap the mower on the wagon and put the wagon on the car trailer.
I would put the wagon on a different trailer to haul unless it's in real good shape. the balers I would put highway tires on and pull as fast as it would go without swaying the tail. The mower I do not know what type it is, if it fit on the wagon I would load on top of that once it was on a different trailer. It will take a couple trips unless you can get someone else to pull some of it. The other option is use a tractor and hook the 2 balers back to back with wagon with mower on top behind that and drive it home. sometimes a tractor ride is faster than all the running around tying to do it with a pickup.got a question about hauling equipment. I just got 2 hay bailer disk mower and hay wagon,, can i haul the equipment be pulled on the hay wagon i live 2 hours away how fast can a hay wagon be pulled. thanks for the help.Ray
We aren’t really sure if these are square or round balers, or the import mini round balers.I would put the wagon on a different trailer to haul unless it's in real good shape. the balers I would put highway tires on and pull as fast as it would go without swaying the tail. The mower I do not know what type it is, if it fit on the wagon I would load on top of that once it was on a different trailer. It will take a couple trips unless you can get someone else to pull some of it. The other option is use a tractor and hook the 2 balers back to back with wagon with mower on top behind that and drive it home. sometimes a tractor ride is faster than all the running around tying to do it with a pickup.
Most generally agree with you.Mower can be a lot of things. If I could load the mower lengthwise so it didn't hang over the edge of the wagon and the wagon is not over 102 inches wide I would load the mower tie it down then put it behind one baler now all you have to get is one baler. This is all assuming they are square balers. IF not then Load a baler and pull it on the wagon and then trailer the other baler and mower on a trailer. IF big square balers then it will be a 3 trip deal. If not cold weather or have a cab tractro of size to pull and stop with. I would load the mower and pull wagon with pickup and pull baler with tractor then take tractor back for the last baler if big square balers. Tractor will also need to be 102 or less wide for legal load.
This. If you load all that equipment onto a typical farmer trailer/truck outfit you will look like the Beverly Hillbillies going down the road and the Kansas Highway Patrol will be on you in a quicik minute, drawn by the appearance. You may not not get snagged for a ticket or fine, but they will check everything about your load and it will cost you about an hour of time. Don't even thinkk of going onto federal highways or interstates.Also check your state laws on moving farm equipment.
