used a JD 214 for years behind my 8N. Now, some will tell you "none", because 8N is too small, too light, has not live PTO. Bigger & live PTO is better, but if you learn how to operate, including the lighter windrows, etc. many thousands of bales have been done with small baler & 8N.(quoted from post at 11:20:31 03/07/15) [b:b3e482fe39]Hello;
I would appreciate your input on what would be a good make, type, style of Hay Baler to use behind my 1948 Ford 8n.
Thanks to all!
walt[/b:b3e482fe39]
t is just amazing! Guy ask what baler to use behind 8N. Few good responses. Many clearly cant read or have sheet for brains. He didnt ask, If I have a bigger, more modern tractor, should I use it. He didnt ask, if I have $50,000 to spend on a bailer tractor, should I. He didnt ask what tractor should I use of my many if I am disabled and sucking on the tax payer's you know what but still able enough to run the eqmt to bale hay. READ THE FRIGGIN QUESTION!!!(quoted from post at 06:39:25 03/08/15) I had neighbor years back. He had three acres of
oats he baled for his horse. He had an 8n and a new
Holland PTO square baler that was made in the 50's
or early 60's. I asked him once how well it worked.
He said "well it takes time!".
(quoted from post at 07:59:55 03/08/15) I have tried it just for kicks, only flat land and a small baler with a motor. A PTO 14T was still too much.
(quoted from post at 09:42:22 03/07/15) They will not handle a square baler that is pto driven. We spent many hours trying to bale hay with one of those ##%%#@# dam things and a fairly new 14t baler. That was in the early 1960's on fairly flat ground. Baler would never tie until we unhooked it and put it behind dads D17.
(quoted from post at 06:16:36 03/08/15) [i:b0c2e1d391]"Since you don't have live hydraulics"[/i:b0c2e1d391]
You mean since you don't have live hydraulics OR live pto.
