Hay tedder question
300jk
We currently have a Deutz-Fahr 2 "star" single row tedder. The center hub area that the arms attach to have been broken and welded several times by a regular welding shop. I believe they are possibly cast aluminum. Dad does the tedding, and usually sets the teeth too low and when be hits an uneven the teeth catch and break the hub. Arguing with him about that is a story of it's own. New hubs can be bought, but he thinks it's time for a new used tedder. So I'm asking to you folks who makes a good smaller tedder ? Kuhn, Vicon ? Looking for opinions. He also said maybe he would be interested in a hay inverter. Not sure what they're really called. I'm afraid no matter what we buy brand wise it'll meet the same fate as the one we have. Dad will be 78 in a couple weeks and sometines he just won't listen to common sense ! So anyway if anyone has any recommendations I sure would appreciate them ! Hopefully he'll let my brother and I take over the tedding duties when we get something else.
Kuhn is pretty good and they built for JD and NH at various times many years ago. I don't think that any make will run in the soil or bang rocks for long without problems so you probably will not see the last of the welding shop or parts dept.
Well hopefully we can dad to give up that part of the operation. In his mind he's still 40. Unfortunately he's much older, and not nearly as careful as he was 38 years ago.
I have a 4 star Kuhn. It has 4 wheels that ride over humps and rocks, never break teeth. Does 2 swarther windrows. Only problem is keeping arms tight.
A friend of mine did lots of timothy acres for years. He said they always carried the tedder on tractor 3 point so if you were going across ditches it didn't dig in when wheels dropped into a ditch. Another thing I have seen here is guys adding wider wheels or duel wheels to avoid wheel going into ditch. I have a really od Kuhn but it seems to work well if adjusted right.
The one we have is not 3pt. It would be worth looking into rhe possibility of a 3pt. unit. Thank you !
We aren't stuck on a 1 row 2 star. Maybe a wider unit would work better. Most of the ruts and rough areas are perpedicular to the field where most of the damage occurs. It has an easement for a natural gas well. When they put in the gas line they left it pretty tore up. This was before my brother owned the property. I think we will probably end up plowing and replanting the field. That should take care of the rough issue.
300 I don't want to hijack your post, Just share my experience. Up until 3 years ago this spring my father was my go too hay raker. He, Just like your father, did not pay attention to what was going on and very seldom turned to look back. Made me furious that I would have to drive clear across the field to tell him that he didn't have the hay rake lowered to the ground.
He would run the wheels of the rake plum into the fence, bending teeth, and rings of the wheels.(wheel rake). The old rake was wore out, but I would not buy a new one, because I knew he would tear it up as well. So I just kept fixing it back, what ever it needed.
Three years ago this May was the last time my father would ever rake hay for me to bale. The Alzheimer's has left him unable to do many of the things he taught me and did his self over his 81 years. April 25th is his birthday.
My advise is fix everything he tears up and take it with a grain of salt. There will be a day when your father will no longer be there to help. Let him do it as long as he wants to and relish every minute with him.
I still have a shelf of replacement parts for that old rake, that I traded for a new one, two years ago. Nathan
I agree. He has always been someone I look up to. Taught me many things, life lessons and has always been there for me when I need something. It's hard to see someone who you hold in high regard get old and not be the person who you think they still are ! By the way Dad's birthday is also April 25. Born in 42.
Kuhn makes a solid tedder. We've had a two rotor 3pt for years You set the angle by top link, you only drop it on position control, so far and it can't drop into a hole like a pull type.
I would not get something wider if the current operator won't look behind, they'll still think it's the width of the tractor like it "always was" and hook it on a tree, ditch or rock.
I'd be fixing the ruts and holes myself.....
We use a 4 star Kuhn I bought at auction. It is old and beat up. I had to replace the center drive shaft and at least 1 pinion gear. It works very well but it is obvious the previous owner set the teeth low, ran the heck out of it and probably did not grease it. Even doubling the bid price with new parts, I am still much less than the going used price. Plus, I am now an expert at working on this brand. And, it does work well. This task is actually enjoyable.
I've had a M&W (rebranded Sitrex) folding 4 basket tedder for over 20 years, it's been a good machine but is not without it quirks. If the adjusting crank is well greased it will crank itself down digging the tines into the dirt in a rough field, also needs to be parked folded out or it could flip over backwards, I wouldn't recommend one for the elderly or inexperienced youngster.
I've been looking at new tedders to replace mine and consider the top three to be Krone KW 5.52/4x7T, Kuhn GF5202THA and Claas Volto 52T or 55TH.
Krone is the heaviest built and most featured of the 3, 18'1" working width is one foot wider than the other two, has 7 tines per rotor, wheels can be angled to throw hay away from the fence line, weighs 1499 lbs but can be used behind a 25 hp tractor.
Kuhn has 17'1" working width, 7 tines per rotor, is lighter at 1170 lbs, the GF5002THA trailed unit I like does not have the angle feature.
Neighbor has a Claas Volto 52T that I've ran, nice machine, 17'1" working width, only 6 tines per rotor, no info on it's weight but looks to be a well built machine.
All 3 of the ones listed have automatic level feature, when you fold it up it automatically levels the tines for transport, when folded out it tiles the tines down to a preset angle, when crossing a small drain in a field one can bump the hydraulic remote and level the tines, then bump the remote the other way angling the tines back into work position.
This is a feature that WILL be on my next tedder purchase, I can set it at the proper angle and don't have to worry about whoever's driving the tractor getting it set right.
All have a transport width of just under 10"
They still sell the GF5001T It's 17' 1" and it has the angling wheels for throwing away from the fence line. Spent a summer moving them damn wheels every field!
Looks like they don't sell the 5001T any more...
The GF 502 THA looks like it might have the angle wheels?
(quoted from post at 12:58:15 04/12/20) 300 I don't want to hijack your post, Just share my experience. Up until 3 years ago this spring my father was my go too hay raker. He, Just like your father, did not pay attention to what was going on and very seldom turned to look back. Made me furious that I would have to drive clear across the field to tell him that he didn't have the hay rake lowered to the ground.
This!! Keep some replacement parts on hand and keep him working. Probably helps him as much as it does you
(quoted from post at 16:50:13 04/12/20) The one we have is not 3pt. It would be worth looking into rhe possibility of a 3pt. unit. Thank you !
I have a 3 pt Kuhn, it's horrible. Were it me, I'd look for a trailer type, 4 basket. I was outlining my woes regarding my Kuhn to a friend and talking about getting another newer 2 basket type, he suggested I look at 4 baskets. They are built much heavier, even the Italian/Turkish ones.
If you look for a 3pt, try to find one with swiveling wheels. You absolutely do not want one like mine with the rigid wheels.
Isn't the Kuhn GF5001T one of those fold back models rather than a fold up, if it is I wouldn't drag one home if it was free, a friend had a Claas model like that, pain in the ars moving from field to field.
GF502THA is a smaller 16'5" model and doesn't have border control, GF502 does but is 3 pt hitch and also 16'5", my old tedder is 17" and will barely cover two 9' mower swaths. No 3 pt for me, I prefer trailed, easier to hook and unhook from, that's why I have a Kuhn GMD2850TL trailed disc mower, the old GMD700 3 pt hasn't been out of the barn in 5 years, may put it on a caddy for a backup mower but will be desperate times when I mount it back on a tractor to mow with.
The Krone has a simple one lever system on the back to angle the wheels left, straight or right, first round you angle the wheels to toss hay away from fence or border, then set them straight for the rest of the field, takes longer to walk around to the back if the tedder than to make the adjustment.
Right now there's a issue with the price of a new Krone and available funding, plus my old tedder is still working, hopefully the funding issue will improve before the old tedder suddenly retires.
My first tedder was a four-basket German made unit (they made for Deere at some point, as well). You could shift the main gearbox slow for standing windrow up, fast for spreading the crop out, and the whole main beam would angle to move windrows over about four feet. I have never seen another with the gearbox. Parts were made from unobtainium and it had been well-used before I owned it.
I replaced it with a two basket Kuhn, and miss the four baskets. I will be upgrading to four soon.
I went through the same scenario with my Dad, not with hay, but running the manure spreader and turning off the beaters without stopping the apron chain feeder. He plugged three loads so bad I had to hand-unload them.
I had to send him home that afternoon, and I was not happy. But I'm glad he showed me his condition- I was aware how far he had slipped and we took measures to compensate. He didn't hurt himself or anyone else as he declined, something we are very fortunate to say.
He was gone in 90 days, the damn cancer got him, but not until he had wrung every last minute of work out of his body that he could give me. God, I miss him.
(quoted from post at 08:51:53 04/14/20)
Isn't the Kuhn GF5001T one of those fold back models .
Yes, it was. The GF5001TH was the hyd folder, same tedder.
I was WELL acquainted with the 5001T, farm had lots of small fields, narrow gates and culverts and the tedder had to be folded every time. I used to plan my work solely to avoid folding and unfolding it and adjusting the angle wheels.
I remember the guy owning say "It was an extra $1000 for the hyd folding one, but I'm not the one running it" (haha)
It would work really good, for what I hay now and I'd take one.
Get the GF7001T...6 rotors to fold wheels to play with.
