Fletch3130
Hay wagon question. I just picked up a 10 ton wagon gear and am going to put a deck on it for square bales mainly. going to go with 16 foot long and 7.5 foot wide. planning to have about 2 foot overhang front and back. going to have some poplar logs off the farm cut 2 inch thick for the deck boards. this wagon will be under roof except when being used in field. my main question is: I am planning to have 2 main beams cut 4"x8" by 16' long. Should I go with oak or poplar? Guy at sawmill I am using said either would be fine. this wagon will be sprayed with thompsons water sealer once per year (usually in the fall). any advice, tips and or tricks you could pass along would be appreciated. also advice on the main beam selection.
