steve terplak
Hey Guys,
I have a New Holland 479 Haybine that has quite a bit of slop in the gearbox at the end of the PTO shaft.
We bought the new parts, removed the PTO shaft from the splined shaft, the cover and seal to the gearbox, the crown nut at the end of the splined shaft, the splined shaft and the outside oil seal. When that all came out, the outside bearing, of the two, came out but not the bearing race.
So, inside the cast housing, we have the race for the outside bearing, the spacer and the inside bearing. Both bearing are identical.
The bearing race is stuck which has left the spacer and inner bearing trapped inside. Also inside is the gear itself.
How do I get the bearing race out? Is there a specific tool or method that works for anyone? Do I need to remove the gear from inside? To drive the bearing, spacer and race out or can I pull from the outside? In order to do that is removal of the other shaft the only way? That seems like a huge undertaking.
Any tips would help.
I apologize in advance if pics are upside down.
![a231717.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a231717.jpg)
![a231718.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a231718.jpg)
![a231719.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a231719.jpg)
