Hi folks,
A couple of times I've replaced rubber that's peeled off haybine rolls with intermeshing steel bars. It's been very successful; I can draw them up in CAD software and get spacing discs plasma-cut at work to space the bars so they provide lots of mesh/crimping action without risking hitting each other if the rolls are slightly out of time or have some backlash. I've done this on a New Holland and a Deere 1209. The New Holland was pretty easy to strip the rubber off (was already peeling) and the Deere was a co-workers, with the rubber so far gone there was almost nothing left. Both times it was a pretty straight forward job.
So, when I pulled out the 1209 at my father's to tune up last night and noticed a couple of lugs just starting to come off, I thought it was no big deal: I'd peel off the rubber, weld the intermeshing bars on, and they'd last forever. Even though a lot of the rubber was good, the rolls are so worn they've long since ceased to crimp very well.
Boy, was I in for a surprise. The two rubber lugs that were starting to peel came off easily, but the rest of the rubber is vulcanized on incredibly well. A combination of pneumatic chisels, pry bars, hot knives, and sawzall blades barely got any off. Way different than the last two I did. So now I've got myself in the stupid position where there's too much peeled off the rolls to try and limp it through another season, but still oodles of work to try and strip the rest of the rubber off. It's a Deere 1209, so a pretty lousy haybine to begin with, and not worth putting much time/effort into. I could conceivably pull the rolls and burn the rubber off, but pulling the rolls on one of these old girls isn't a small job either, and not really worth it for an old 1209.
Has anyone else stripped rubber off haybine rolls? Any suggestions would be greatly appreciated. Probably makes sense to just haul it to the scrappers and find another. Or else just trail the disc mower down from the other farm - but that's 110 miles away: a long way to be trailing a disc mower back and forth during haying season. We typically do less than 20 acres at my father's, so can't justify buying a decent discbine for that little acreage. Any used old haybine I find will probably bring it's own pile of problems with it, however. plus the fact that used equipment around here is going for stupid prices. A neighbour just sold a New Holland 488 with a pooched wobble box and rolls that were pretty marginal for $3500.
