Hazmat endorsement
JimS
I will be renewing my CDL license later this summer and was going to add a tanker endorsement as I have need to drive a water truck. I am considering an X endorsement which is a combination hazmat/tanker endorsement. I've been cautioned about doing this as I will have to take a physical more frequently, be subject to closer scrutiny, and I think it need to be renewed sooner. I don't really need it but I figured while I am at it to add it. I don't anticipate needing it but I didn't anticipate needing a tanker endorsement either. I want to do any endorsements at the renewal because doing them any other time requires me to retake all the tests.
What are the pros and cons of having a hazmat if I absolutely do not need it? Should I get it? Thanks.
Personally I have a non-hazmat tanker endorsement. I thought about getting the hazmat, but decided against it because I would probably never have the need for it. I mainly haul water and sewage when I have to pull a tank. It may vary from state to state I don't know, I'm in Illinois.
To get the hazmat endorsement, you need to first pass a fingerprint background check.
Then you need to pass the written endorsement test. Everytime you renew your license in the future you have to repeat this process. There are no other requirements that I am aware of. Have had all endorsements except P on my license since I was 18.
Hazmat background check
had all endorsements drove truck and trailer fuel truck , if you go for it study your butt off most fail the first time
I had it all until I retired. I had to, pulled a lot of hazmat tanks. You have to be finger printed and background checked every four years, I think, which costs about $150. Plus I have to have a permit to enter any place considered a port, I cant remember what they called it. It pretty much included any facility along any river. That was another background check and another fingerprint and another $150. I don't know why they can't share info, unless it is to collect more money.
When I was in the Marine Corps I had a nuclear materials endorsement on my government license To get that, they give you a book about an inch thick and basically tell you to memorize it.
I didn't need it myself, but I had collateral duties as Motor Transport NCO and I was responsible for getting the proper licenses and endorsements for those who did need it. I figured if I went through it myself I'd be better prepared to help the guys that needed it.
(quoted from post at 20:37:38 01/10/21) To get the hazmat endorsement, you need to first pass a fingerprint background check.
I dropped my X endorsement after they came out with that. Just another government hassle which won't stop the terrorists from stealing a tanker truck and doing what they want anyway.
I have had a CDL or what would be that since I was 16 due to what I did. I was forced to retire when my doctor found out I was driving truck again. My CDL has every endorsement other then school bus and Haz-mat and I'm not giving up my CDL
I had every endorsement until my dad got rid of his school bus so I let the P drop off.
My company requires I have doubles; haz mat; and tanker for my job.
I use them daily as I pull doubles.
The tanker endorsement is a piece a cake.
Take the test one time and pass and you are good as long as you keep it current.
Use to be you only needed a tanker endorsement if you had a single tank 1000 gallons or more.
Not so any more.
Now you need a tanker endorsement if you have 1000 gallons in bulk containers. IE: 119 gallons or more.
Hauling 5 - 250 gallon totes now requires a tank endorsement.
The Haz Mat is a different story.
You need to go a couple of months before you go get the license to a 3rd party fingerprint site.
They use your fingerprints to do a federal background check on you.
Just like getting a TWIC card.
Once the background check is done they will notify you so you can go to the DMV and get the license.
You have to take the Haz Mat test every time you renew your license.
It is the only test you have to take at every renew.
This finger printing and background check adds about $80 to the cost of your license if I remember correctly.
The back ground check is good for 5 years.
So if your state gives out 6 year license your license will expire in 5 years on the date your background check expires.
It does not effect your physical or put you under any other scrutiny other than the background check.
The only thing the Haz Mat does for you if you do not need it now is allows you to find a job tomorrow.
Just about every licensed Haz Mat hauling company is looking for drivers because no one wants to jump threw all the hoops.
I have had a commercial license since I was 18. THe physical is the same,in my case it is every year,I have diabetes. If you let your physical expire your cdl reverts to a standard license. THe card he was trying to remember is a TWIC card,if you need one you will know it when you can't deliver somewhere. It is for companies that have docks. My company pays for the fingerprints and the physical,because of the diabetes I have to have an eye test that I pay for. I have never seen what the big deal is,know your stuff and take the test.
Judging by what I used to see on the road, a HazMat endorsement usually meant you were dealing with an above average trucker that was professional and intelligent enough to know what he was doing. I know they used to get paid more than Joe Sixpack with his Class B. The big thing is to obtain some sort of flow chart to make sure you are on the up and up when hauling HM. We used one we modified from an industry outlet on the enforcement end. Made life much, much easier for everyone. Same for tank stuff, get a flow chart for the type of tank you'll be involved with.
Jim, when it is time for your test you may want to verify before you go whether the tank truck should be full or empty. This has been an issue the last two times that our FD has taken someone.
I dropped my hazmat when the foreigners could not speak english and could still haul it. didn't pay any better to haul it back then anyway so why do it. For the farm I was exempt for what I needed to haul so no need for it. Kept the tank endorsement though along with the rest doubles and what not. When I grandfathered in for the communist drivers license they would not let me get the Passenger on it. I still have it and probably will keep it till I stop driving period.
Access to a dmv office may be a little harder because of nnalert.we need to get an appointment here in Louisiana call ahead to be sure
(quoted from post at 10:02:43 01/11/21) Access to a dmv office may be a little harder because of nnalert.we need to get an appointment here in Louisiana call ahead to be sure
Yes. In my town appointments are 2 months out. I can go to a bigger city and walk in. Go figure. Got my paperwork and now I have to stop in and get my new concealed carry license card next.
I carried a hazmat endorsement for 20 years when I hauled fuel for a living. I dropped it after I started hauling grain, WDGS, and litter. The fuel hauling did not pay as well as other trucking, and the Hazmat is a huge pain. I still have a CDL with tanker, doubles/triples, and every other endorsement, except passenger.
We have a computer program our company bought.
They say it is the same program the DOT uses.
You enter the UN number; weight; and if it is bulk or not.
It tells you what placards you need and if any segregation is needed.
Just guessing but I assume it is sold by JJ Keller.
The good part; at least with our company; It takes the burden and mostly the liability out of the drivers hands and puts it in the supervisors
hands. As long as we do what we are told by the print out they give us; we will not be disciplined if it is wrong.
Honestly, I don't think it is worth the headache to get hazmat. First there is the fingerprinting and background check that takes time and costs money. Then there are a whole new set of rules that go with hauling that stuff.
I hauled a few loads of some really nasty stuff, and I was on pins and needles the entire trip each time. Thanks, but no thanks!
Unless you are working for a carrier that requires it or if you plan to apply to a carrier that requires it, I would leave it alone. Why invite trouble?
I hadn't thought about how young some of the guys are on this forum, grandfathered in and got my CDL's when they first came out in 92-94, don't remember exact year, but I got everything but passenger bus, hauled more hazmat before CDL's than after, when they started finger printing and stuff I hadn't hauled hazmat in a while so I dropped it. Retired from professional driving in 08 after 30 years but still have my CDL's, better to keep them than go thru the trouble to get them back should I need them again.
Hauled a load of rubber that had one drum of rubber adhesive with the load, the adhesive was flammable over 50 gallons so hazmat placards were required.
Short time later hauled a 44000 lb load of 8" artillery rounds, it was considered non hazardous no placards needed.
I was more concerned about getting in a accident with the artillery rounds than with one drum of glue
I will add that at least in IL you can not drive a hazmat truck to take the hazmat test. We seem to hire one new driver a year, and we have to strip s truck down for their road test. WE have one tanker in town,the DMV wants it empty and all placards removed. To do that it would cost hundreds of dollars to evacuate the tank and have it certified clean.(the tank truck is a manual transmission,the rest of the fleet is automatics.)
(quoted from post at 15:16:45 01/11/21) We have a computer program our company bought.
Cool! 10-12 years ago we didn't have that, although we did use Keller products in other areas. A flow chart made life SO MUCH easier!
