Goose
I had to have a rear wheel rim replaced on my M Farmall because it rusted and split. I bought a good, solid used rim, and cleaned it up and painted it.
However, our local co-op no longer has a tire truck. So I called a fellow nearby who has a one man tire shop and does rear tractor tires. He came with his truck with a boom controlled with a hand held remote. Swung the boom over the tractor, put a chain around the axle, lifted the tractor and put a jack stand under the axle. Pulled the tire off of the old rim, swapped rims on the tractor, and reinstalled the tire with a new tube. No fluid in the tires.
It took him less than an hour. Quite a truck, from the remote controlled boom to push button hydraulic outriggers to stabilize the truck from the weight of the tractor. I won’t hesitate to call him again.
