head bolt lube
andydap
hi again, this time what do you think is the best lubricant to torque down head bolts? and if its not just oil, where can i get it?
I second the choice of ARP lube. I did some tests of different lubes and the ARP lube will gain you between 5 and 10 percent clamping force with the same torque wrench setting.
Ed.
hi, no, not that i can see but i had a comment from someone else who suggested to use a sealant on the right side of the head where all the coolant openings are. he said to run a bead above and under the gasket around each opening. he gave the name of the product but i forgot and didn't right it down. any ideas?
