JimS
I'm trying to find head bolts for a 97 Isuzu Rodeo with the 2.6 but I am unable to locate them. How critical is it to replace head bolts in any engine? I know some of the new ones are stretchy and are meant
to be replaced but what about older engines? When unable to find head bolts, what do you do? What are some sources for head bolts?
I simply google your descrition
"head bolts for a 97 Isuzu Rodeo with the 2.6"
and it returns many options
I use a real computer with microsoft windows 10 operating system
and google chrome as a browser and search engine
Generally speaking studs are favored over bolts. I am sure that a project that I had last spring would not have worked with bolts. I used ARPS studs and I got full torque on them. look up ARPS. they will have them
My experience: older stuff like '70s and '80s I've reused multiple times with no issues. Newer TTY design requiring replacement I thought was BS, "Just a way to sell more parts!" I told myself, until I had one break; this was on a '99 Jeep 4.0 I6, got to pull the head and start over. $50 or so for a new set of bolts isn't worth the re-work or risk of engine damage due to teen drivers not reading gauges and overheating.
"Generally speaking studs are favored over bolts."
Of course. Unless you've got an application that doesn't give you enough space to lift the head up because of the length of the studs.
(quoted from post at 18:59:39 09/04/19) "Generally speaking studs are favored over bolts."
Yes, that is obvious enough that it goes without saying, right?
Should still run a tap and dies over the threads to ensure they are clean. The top thread in the block should be counter sunk out to ensure better clamping of the head.
They are not torque to yield bolts. There is a two step torque process starting with the middle bolts and working your way out. Step 1. 58 lb-ft, 2. 72 lb-ft. Lube the threads and bolt to head contact surfaces with eng oil.
