Head gasket?
rubicon1234
Changing oil on a John Deere 2010. Oil has some water/coolant in it. Last oil change was one year ago. Do I have a head gasket issue? Can it be condensation from cold weather? I don t have a shop manual, does this gas engine have wet sleeves? Thinking I should pressurize the rad and see if I get coolant in the oil pan. Or maybe send the oil sample out to see if it is coolant or just water? Let me hear your thoughts.
The best way I know of, is let tractor sit
for a lengthy spell (several days) before
doing an oil change. And loosen the drain
plug up enough for it to just drip (don't
take it out). Just loosen enough for a
drip. If what drips out is water, and un-
mistakeably green, then it is antifreeze
(coolant). Not condensation.
Of course this has to be done without
starting or warming up the engine before
loosening the plug.
If you just took the dang plug out, and
paid no attention other than, I thought
some of that might of been water, then you
just missed your best chance to figure
things out.
The water will settle to the bottom of
whatever you drained the oil in. The
problem with that is though, whatever you
drained it in, likely don't have a drain
plug in it.
So you can either put plug back in, do a
coolant system pressure test, and let
tractor sit for awhile, and see what (if
anything) shows back up in the pan. Or you
can just complete the oil change, operate
it for awhile, and check things out again
as mentioned above, the next time you do an
oil change.
As to dry sleeves or wet sleeves, I can't
answer that one. If I had to guess, I'd say
dry sleeves, but that's just a guess, as I
don't know for sure on this model.
Not sure if they are wet or dry. Are they not one of the engines with the sleeves and a plate all fastened together in one big conglomeration, and expensive to fix because of that?
is radiator low? pressureize radiator let set under pressure a couple days n see if coolant is present.it could be condensation if not used long enough to warm engine up to operating temperature.
those sleeves seems to me are in a complete pack joined in 1 piece by a header,costly too.
hope you just got condensation
If you look closely you will see a plate between the top of the block and the head. That is the deck plate and all the sleeves attach to it. So four sleeves and the plate are one piece, and
they are wet sleeves. Famous for failure. I would pressure the cooling system with the drain plug out and let it sit for a couple days and see what it any moisture comes out. I hope you do
not see anti-freeze, if you do several thousand dollars will get you fixed up. I believe the deck sleeve assembly assembly is still available from Deere.
Wet sleeves on one plate. Had a combine
with that same motor. Just put stop leak
in it. 2010 aren't worth much. Unless it's
got semential value.
On the head gasket question, you're guess is as good as any of ours.
If you can afford to have the tractor down, I second the recommendation to let it drip for a while and see what comes out.
If you need to get it back into circulation ASAP, then hit it with some stop leak as a preventative measure.
My uncle had a 2010, and he had to junk it because he could not get parts. Nothing at the dealer, virtually none in the salvage yards. Sure, if distance and cost made no difference, he could get it fixed, but it would have been many times the value of the tractor.
Condensation is definitely a thing but redforlife nails how to find out if it's coolant. And you don't have to wait till next oil change, just give it a few days, or longer.
This post was edited by WilBury on 10/20/2022 at 05:24 am.
Wet sleves made in one piece attached to alate on top called a deck plate. You pull it and you can see every bit of the inside of the block. I am not positive how the sleeves fit at bottom but am thinking sealed with an o ring that is starting to fail. I dought that the sleeve is going to rust out or crack as they are heavy cast if I rember correctly about a half inch thick..The deck plate was not avaible new years ago but was substituted with the 165 deck olate used on later engins. That same engine was used in the 1019 but with a deck plate of 115 CU In. and the 115 engine was used on the 40 combine, the 145 on the late round back 45 combine and the 165 version was used on the earlu square back 45 combine. So thinking it probably is a 60 year old O ring starting to fail and if it is that all that would be needed would be new o rings and deck plate and head gasket. Post just a few days ago on combine section same problem as this. This assumes it is a gas engine and not a deisel that I know nothing about. I had 2 late RB and 1 early SQ BC 45 combines. Late Square back uses a 180 cu in engine that was entirely different. Parts book will tell if an O ring in there. My books not avaiblenow.
Remove the oil fill cap.
Look under it for condensation droplets.
Touch them with finger and taste it and spit, you will know your getting antifreeze leaking into the crankcase by the sweetness.
I had a ford truck that sat for quite a few years. It had water in the oil. After refilling it I didn't see any more indication of water after I got it
running. I just figured it was condensation. Stan
