Jim Phillip
Have a Yanmar 240D that I replaced rings and head gasket on last year. Put about 40 hours? on it and shut it down without problems. Tried to start it when it was cold unsuccessfully. It would just crank and not fire with white smoke. Figured I'd fix it when the weather warmed up. Sat for 4-5 months and I just bled the fuel lines and it started up easily (on a hot day) but I noticed bubbles from the radiator into the overflow bottle which I know is usually a blown head gasket. Should I re-torque the head and start it again to see if it stops bubbling before I remove the head and check it all? Or is that a bad idea? It seemed to be pretty warm when I shut it down after maybe 10 minutes running before I saw the bubbles but the idiot light wasn't on and it was 85deg. out..
