head lights
LDoyle
I read on here somewhere to run two wires to your lights { instead of grounding one inside the light)on a 6 volt + ground system for much brighter lights . I came off battery with two 12 ga wires ( + and - ) , one went through a switch , to lights but they are not bright at all . You sure couldn t work under them . They are the old lights , do they get weak over time or do they just work or not ? Or am I just not doing something right ?
6 volt lights are not that bright. If you need more light may need to convert to 12 volt. I have lights on most of my 6 volts tractors. About all they are good for is finding the way back to the shed.
(quoted from post at 11:11:06 09/26/13) I read on here somewhere to run two wires to your lights { instead of grounding one inside the light)on a 6 volt + ground system for much brighter lights . I came off battery with two 12 ga wires ( + and - ) , one went through a switch , to lights but they are not bright at all . You sure couldn t work under them . They are the old lights , do they get weak over time or do they just work or not ? Or am I just not doing something right ?
A copper wire has a lot less resistance that steel especially on the older tractors when the current has to pass thru bolted frame parts , rust and paint. Even on 12v systems, lights and other electrical things work better when multi-strand copper wire of at least 14 GA is used for both positive and negative runs.
the way you ran your wireing.. your ammeter has been defeated.
all loads need to come off the same side of the ammeter as the generator's reg-bat connection and the ignition.
dim lamps??
what wattage? 30w ain't too bright..
make sure they are getting good connection in the buckets
You did not hook them in series did you. Two wires have to go to each light. Positive to each and negative to each.
Are your lights both in fact 6 volt?
I have a + and - from the battery to first light then from that light to other light . Are you saying I should have FOUR wires from battery , 2 + and 2 - with a seperate + and - going to each light ?
I didn t go through the ignition switch so I could turn lights on without turning switch on .I m thinking now only drive it during daylight hours .I thought it was pretty simple......maybe that's what is wrong , I thought .....
I figure since I never run my tractors at night I don't need lights.
Whenever I get a different tractor I immediately take the lights off so I don't mash them or tear them off.
Then I somehow forget to put them back on when I sell the tractor
I'm starting to get a pretty good pile of them in my garage.
Lights need to be wired in parallel from the load side of ammeter. 2+ and 2-, one for each as stated.
They way you have them, in series, is what's killing their overall output.
I mow at night all the time with my 6v 8N with no problem. Running both headlights and rear work light. No issues.
for mine i used one of those flat 4 wire trailer light connectors. gives me the 2 wires to each light as well as a quick disconnect if or when the hood needs to come off.
