head lights
Hey guys ,i bought a 100 and found out it has 140 headlights on it. They have a two prong plug on them instead of the one wire lights that are supposed to be on it. Anyone know how to make them work on the 100? im converting it to 12 volt and bought a 12 volt switch. Thanks, Phil
If the lamps are 12v, it will work as follows: wire the supply wire to one terminal and a second short wire to attach from the second terminal to the body of the light fixture (ground). use the same terminals on each lamp to avoid confusion later. Jim
