Need some more info. Do you have original doglegs? If so they have a 'knockout' where the light goes. Are you using round brackets or wing brackets? If you are using wing brackets you will have to drill out the second hole.
It"s an 8n with original dog legs they had patch work done to them and then painted so can"t tell where the holes were. I have new ford head lites and wings, would like like to put lights in or close to original spot
Thanks
Eldon
The hood isn't that hard to remove. Maybe if you take the hood off you'll be able to see the original hole locations from the inside. Just a thought.
You might be able take the lower bolts out of the dogleg, drop the grille & pull them out enough to see where the knockouts are. If theres enough slack there, maybe even tap them out with a small ballpein hammer.
