Headlight switch wiring
Which wire goes to which terminal on headlight switch?
Installing 6v+ gnd headlights to 52 8N.
Installed lights, wiring & fused switch.
Added extra ground wire to each light.
I know electrically the switch doesn"t care but:
Which switch terminal does headlight harness wire attach to?
Which switch terminal does jumper attach to?
Which junction block terminal (below ameter)does 5" jumper attach to?
Which end of jumper (one closed loop terminal one hooked) goes where?
Thanks, Clem
Clem........as you pointed out, the switch does not care and neither does the wiring harness care. Which ever is convenient. Simple, eh?
As for the 2-terminal distribution block, connect yer lite switch INPUT to the common everything on it stud. NOT the ignition switch output to the roundcan ignition coil. Simple, eh? ........HTH, Dell
