headlight wire
MnNC
hello friends of the N
i removed headlight wire from behind dash
now trying to remember where to put it back
thinking it came off switch post....does that sound right? my N is a 2N with 12volt system. "46 Ford Ferguson with hi/lo trans. been a good "un :-)
If you wire it through the key switch, your next project will be to replace the key switch! It can't handle the current flow to the lights.
Wire it off of the lower (center) terminal on the terminal block.
75 Tips
(quoted from post at 18:39:44 05/16/14) If you wire it through the key switch, your next project will be to replace the key switch! It can't handle the current flow to the lights.
75 Tips
thanks Bruce ! knew i could count on you guys :-)
