bamaman
I need to replace the headlights on my 67 5000. I see a lot of full assemblies for sale.....but have not found the correct size sealed beam bulb. Anyone know where to find them?
not sure what buckets you have. but if it's the common buckets.. lamps are easilly available for them my manual is at home.. can't remember the ge number offa my head um.. 4419 sounds right.. again.. not sure what buckets YOU have..
I agree with soundguy's part number. Just last Friday I knocked my right headlight loose picking up a piece of equipment with the front end loader on my Ford. Tightened everything back up and then discovered the bulb was shot. Took it out, went to local CARQUEST in town. Laid said bulb on counter and about $9.00 later I had a new bulb.
Thanks Guys! NAPA and CARQUEST both have 'em. I failed to mention I will probably need the bezel/ring since they will likely break when I try to loosen them. My buckets are original.
The 6-VOLT Sealed Beam part number is 4019 and the 12-VOLT part number is 4419. Common parts and any auto parts store or tractor dealer should carry them.
I have some original FORD Tract-O-Lite buckets for the Thousand Series tractors if you need any. Also have N-Series 'tear-drop style' buckets, and later round T-O-L Hundred Series buckets. Some fully restored. Also, I have some original taillights -DUOLAMPs, early and late.
Tim 'PloughNman' Daley
