randydale
I was wondering where i should run the wire for the front headlights. The tractor did not have any lights when i purchased it. I heard that the wire can be ran to the ignition just not sure on which terminals.
If you run the lights through the accessory connection on the ignition switch, you won't often leave the lights on with the engine not running. But you probably want another switch for the lights after that so you can run without the lights.
Gerald J.
To Run the tractor WITHOUT the lights, In some CONVENIENT Location Maybe near the other Panel Instruments Temp Gauge ETC... Just Cut the Positve "HOT" Wire and simply put a Toggle switch in the line. Larry KF4LKU
Once you hook onto the ignition switch ( might do like was suggested and hook it up so they only work with the switch on) put an inline fuse in, and then the switch after that. Depending on how many lights, I'd use maybe a 20 amp for up to 3 or 4 bulbs, and 30 for any thing more than that.
Be sure to get a good fuse holder too, not one that's only rated for 10 or 15 amps. They'll burn up in short order.
Donovan from Wisconsin
sounds like it might be a little bit easier just to run them to the ignition switch. do both ends of the wire run to the same terminal on the ignition switch or do they run to different terminals?
If you're going to run more than 3 lights I would run them thru a small relay to prevent your ignition switch from melting some time down the road.
Be sure to put a fuse as close to the power supply in that circuit as well. This is why head light switches are more heavier duty than the ignition switches.
Randy...on the Light it's self,The Body of the Light is GROUND, the Single Wire is POSITIVE, 6/12 Volt whatever the case may be,Is where the Toggle switch goes, Connect to the Ignition if You want, Just CUT the Wire at a Convenient place to Mount the toggle...and You are in Business, put the Toggle in Series and this way You have actually Two (2) ways to Cut Power to the light.Hope this clears it up.. Larry
