Heater problems/ Mopar
504
Totally a tractor question(if it doesn t run then I can t go for tractor parts) We have a 2005 Caravan and the blower on the heater quit, as near as I can tell I have electricity to the blower, question is do I have to remove the heater-AC box or can I get the fan motor out by itself? I have removed four screws but I can t see any more(of course it was snowing and cold as I was under the dash looking.
power flows to blower then resistor to fan switch that provides ground. bump fan housing and see if blower will run. If you only have 12 volts to blower and no power out your blower is open and needs replaced.david
