HELP 10' kongskilde triple k
Rogerworco
I have a 10' kongskilde triple k.
The wheels are supposed to raise and lower but the pins are frozen or stuck ....not sure if they screw out or slide out but so far I have not had any luck ...anyone know anything ...see pic .
[/img]
This post was edited by Rogerworco on 09/12/2023 at 06:00 pm.
Not familiar with that brand, looks like a depth
adjustment wheel, The circled area looks like a hole to
me, dont see a pin. That said, I doubt the pin is
threaded, most likely rusted in. Use a good penetrating
oil, not WD40 and soak it down good daily and rap it a
few times with a big hammer every day for a week and it
should loosen up Diesel fuel and ATF mixed 50/50 works
good. If that fails or youre in a hurry, heat is your friend.
They are not a through hole, they are a nub that protrudes from the square nut inside for the threaded adjustment, should turn and move up and down easy, if the crank doesn't turn you have a rusted and seized thread.
(quoted from post at 06:59:47 09/13/23) They are not a through hole, they are a nub that protrudes from the square nut inside for the threaded adjustment, should turn and move up and down easy, if the crank doesn't turn you have a rusted and seized thread.
So that nub is not a pin and does not come out of unscrew .... ? If the adjustment wont go up and down its because its rusted /frozen on the threads .....correct ?
Yes, nub is part of nut, the assembly will only come apart if you are able to turn the thread and move the channel up, most likely rusted/stuck.
