Help - 2002 Cheby Fuel (Gas) System
kruser
Prolly been discussed on here before BUTTTT getting real tired of this!
6.0L in a 2002 3/4 extended cab. Fuel pump was replaced at about 40 K and then again around 80 K (both under "warrenty" by GoodWrench.
Wifey calls tonight - same thing as this fall. Ahh, not the first time. Turn the key - might not. Once you turn the key and it don't start - shows no fuel.
Fuel sender or pump?
Jim
All new pumps now come with a new connector,,, never seen a old one fail but GM did change the connector... I have also seen the connection were the fuel pump relay fits into the relay center B bad and knock out the pump,,, this happens cuzz some dummarse while check'n the circuit backed probed it and spread the connectors,,, the tell tell was the relay would get hot,,, the fix was to slightly twist the pins on the relay...
Lots of info out their Google it...
http://www.youfixcars.com/chevrolet-fuel-pump.html
