Help a spare part!
TinCan
I had pulled my lift cover apart on my '63 4000 about 2 1/2-3 months ago. Then I ordered O-rings, built a new motor for my truck, had a accident with our Blazer, and broke the wives back (remember if the wife isn't happy, then no one is) well I got the car fixed, wife is still broke. I need to get the lift cover back together again. I started to reassemeble it, but I have a spring, I can not find where it goes! I did not take the lift cylinder apart. I can not find it in my parts book, or the service manual, or on Messick's online parts.
I have two springs, I know one goes into the detent of the hydraulic lift draw bar position control. But I don't remember where the other goes. Can someone help me out?
I believe the short spring is the detent spring. Not 100% positive.
Thanks, Pat
No, the proportions in that parts drawing are not right. 58 is the large draft spring that is external to the lift cover. I believe they are 3 and 42.
I did not take the position control arm, and the draft control fork assembly apart, I cleaned them that way. so they still have the springs on them.
I have not opened up the lift cylinder, so that spring is not from it.
I was told not to mess with opening up the cylinder, it was to much of a can of worms. I forgot about it. But I believe it should have a look-see inside & cleaned. but I don't want to just replace parts to just place them (O-rings don't count). I will if need be though. What do you think, is it a simple thing to open and clean, and get back together? I mean hell, look at what I've gone through so far with this tractor! lol!
Remember, I haven't removed a bolt that hasn't been holding something that's broke, need's replacing, of fixed yet!
Still need to find where the spring goes!
Thanks, Pat
(reply to post at 06:45:44 05/13/19)
Has the lift cover been disassembled?
If someone can attach a link for the lift cover section 05A02 there's two springs in the check valve assembly, items 24 and 30.
As for the lift cylinder you need to remove piston # 25 to replace the o-ring and backup ring #'s 29 and 30.
(quoted from post at 09:48:55 05/13/19)
aybe?
(quoted from post at 10:48:55 05/13/19)
The piston (#25) has been removed, and replaced with new o-ring and backer.
What I'm wondering about is the other pistons & O-rings on the side of the lift cylinder. Parts 1, 4, 5, 6, 7. & parts 11, 13, 21, 22, 23, 24. Should I remove them, and replace the O-rings in them also. I do not want to wreck any thing taking it apart. If I won't, then I'll pull it apart and clean it, and replace the O-rings.
Thanks, Pat
(quoted from post at 11:32:10 05/13/19)
aybe?
JMOR,
In your picture, I only pulled out the parts up to & including the steel ball. The next part is taped 5/16-24. Can I just thread a stud into it, put a plate & nut on it, and extract it out?
I was told to leave it in, if it would move on the spring inside.
Thanks, Pat
You can, but..............there have been several reports of it breaking behind the threads & apparently true as even the FO-20 manual suggest a method of removing the broken part.. Probably wise to leave it alone unless a very good reason to remove it.
For what it's worth. I recently used JMOR's method of removing the valve seat from my lift cover and it worked quite well.
However, the threads on my valve seat were 3/8-24. Not 5/16-24. If that is a typo please disregard. I suggest you ensure you use the correct size and thread.
NineSixtyOne, It may be, I just grab a fine thread bolt out of the bin, and it thread into it, I was more into if I should pull it or not. I just don't like leaving parts left untouched/cleaned behind. But I also have this guy called Murphy hanging around this tractor, and his law s**k's!
But I still need to find where the extra spring goes!
Thanks, Pat
