Hello Everyone,
New tractor owner here. I decided to purchase a 1957 International Harvester 300 Utility with a Davis Hydraulic Loader (model 102). The loader was leaking hydraulic fluid like a sieve from the oil filter housing cover; so I decided to tighter the cover bolt. In the process of tightening, I broke the middle shaft inside the oil filter housing that the cover bolt screws into. It essentially snapped at the base of the oil filter (farthest inside the housing) and covered the garage floor with hydraulic fluid. So a couple questions...
1. Is there a place I can purchase a replacement oil filter housing? Or is this something that someone could possibly weld the pipe/rod?
2. Does anyone know where I can get replacement inner components and what the corresponding model numbers are for those parts (ex. oil filter and gaskets)?
Thank you all!
Jonathon
Thank you all!
Jonathon
