Help; Ford 500 diesel injectors?
JF in MI
I have a Ford 5000 4 cylinder diesel and need a set of injectors for it but the ones I see (that look correct) and are listed for a 5000 seem to come only in sets of 3. Do the 3 and 4 cylinder use the same injector and/or what am I missing here? What would be the correct part number for my application?
this site (YT) sells them individually, buy one or four, you make the call!
Depends on which 5000 you have
65/mid 68 have smaller 233 ci engines that use the same injectors as a 3000 3 cyl
Mid 68/75 models have the larger 256 ci engine that use a different injector
There’s a lot of generic listings today that try to tell you one size fits all
I ordered a 4 cyl valve cover gasket that had 3 cyl models in the listing
I'm not even sure what year it is let alone engine. Ser# on lower side of block is R247806, does that tell you anything?
