HELP / hatching turkey eggs
Anonymous-0
Soon it will be time to hatch turkey eggs again. I am still having bad luck at hatching eggs, the chicks are dying at about 19 days inside the shell there seems to be an excess amount of moisture in the shell when I break them open after not hatching I go be on the hatch day by 3/4 days befor opening to see what is going wrong. Is it true some people hatch turkey eggs with low humidity. Thanks for incoming help.
Pat
I have had some experiance hatching wild turkey eggs. These are eggs found when I ran the hens through the haybine. My 1st incubator was a cheap one. I had to turn the eggs by hand. New incubator is automatic with timer. Humidity was maintained by keeping saucer with water in incubator. We actually had pretty fair luck with them. Good luck to you.
DANGER DANGER DANGER! You got away with that?! My cousin did it ONCE. Somebody called the DNR and he got a $150 fine out of it. He asked what he should do next time it happened,they told him call the DNR or run over them.
