HELP hydraulics quit again
I have a 1964 Farmall 460 diesel. I had a major hydraulic leak from the brake shaft seals, power steering supply line and the main hydraulic hose and I lost all hydraulic power. I repaired all the leaks and hoses and replaced all the hydraulic fluid. Hydraulic pump made a slight whining noise when I first started the tractor but then it quieted down and the hydraulics worked perfectly. I ran the PTO and everything seemed perfect with no leaks and worked great. I was able to remove my cutter, shuffle around my baler and rake and when I moved my baler to the shop the hydraulics started acting up again. Moving very slowly and jerky and the hydraulic pump is whining a lot. Is there a way to test the hydraulic pump without just removing and replacing it? Is there anything else I should be looking at? I did find that the brand new fluid after less than 1 hour of use was extremely foamy already. Any help is greatly appreciated.
Foam and whining are signs of air getting sucked into the pump.
Low level, restricted suction strainer, air leak between the tank and the pump.
