Help ID Case Tractor
mspurlock
New to the forum and forum world. Trying to learn to navigate it.
I recently received the first tractor my Great Grandfather and GG Grandfather purchased together and am excited to clean it up and ride it around. I was told by an Uncle he thought it was a 51 by what I have been able to find online about the serial number it appears to be a 49? (VC5360012) I see a few models and I?m not sure the difference ie. VA , VC , VAC. Help there also please. I got it running, and drove it around the yard. Has a few leaks that are next on list before any beautification work.
I would appreciate verification on year, model, and I see there were some options on ?eagle lift? around then. I just want to order some service/parts manuals and parts and be sure I am getting the right stuff. Thanks
Pictures should be attached.
I also got what I believe is the original 2 plow set for it. We?re there any other implements that came standard around then that I should search the old home place for?
This would be a good one to post on the Case portion of this board. Its a V-something, I think, but I've never seen that lash-up on the back. Those guys would know, and would wax eloquent for hours on it, I'm sure.
Nice looking Case for sure!!! Will be a great learning project, just remember there are lots of people here that will be more then willing to help you out!!!!
VAC. them were peppy little tractors for only being around 20 horse. Cousin brought one right out of the field and hooked it on the sled. Took second place against 8 other tractors that were set up for pulling.
Thanks,
Tag is still on the dash. I don?t know what happened to the picture I had of it. I read on here somewhere that 53 was a 49? This is the serial VC5360012
Nice looking tractor. It's a VAC. It must be a very early 49 not having the Eagle Hitch. The hitch on the back is the pre Eagle hitch. It is for a cultivator.
The third picture shows a part # that is actually in the mold when the item was cast. The serial # indicates it is a '49. It is a "VA" series, the "C" in the # indicates it is a "row crop" model. The earlier "V" model looked like the "VA" model, but has virtually no parts that exchange with it. The earlier "V" series used the same Continenal engine as the M-H Pony & Allis Chalmers G. The later "VA" series used an engine designed by Case. The idea for the smaller "V" & "VA" series was to compete with AC, IH & JD for the small farmers that were converting from horse power to mechanical power. jal-SD
It was used on his little 15 acre farm from ?51 until 2009 when his health no longer allowed him to use it. All this info has been great. Thanks, I will post this over on the CASE forum and maybe get some tips and advice.
The square hole in the casting, right near the bottom of the grill work on the front of the tractor. Is to accommodate a tool bar for a mid mount cultivator. It would be nice to find this equipment laying around the old place.
I guess I should have added there was a few 49's with high pressure hyd like that one,, I see so few of them I normally do not add that Eagle Hitch came in pretty early 1949 production the one above was one fo the last so to speak with that system
cnt
Thanks Bruce, I assumed it was to mount something. I need to look around the old barn before it falls in. It s just about 8 hours from me. I seem to remember a side mounted sickle mower on a tractor when I was young but I know at that time he had another tractor that was a little bigger. Could that have been mounted on this tractor?
I see in photos online a flat belt pulley on the pump. I m going to see if I can find it also on my next trip. I ve got to pick up an old steel wheeled wagon. Pretty excited to get it all sealed up and do some hay rides for my daughter. I d love to break some ground ,just for fun, with it also.
JAL .....good info for the poster's question but your reference to the engine in the V series wasn't spot on. The Continental engine in the V series was a 124 cubic inch version, the Continental power plant in the Pony and AC G was about half that size. That same 124 (and then the 140 and later 162) was used in a lot of Massey Harris tractors as well. You're right about virtually no parts being interchangeable between the V and the VA models, even though they looked very similar ..... one part that does interchange is the shaft that transmits power from the engine through the clutch to the transmission. I replaced one in a V that I had and I tore apart a VA to get it.
You can have a ton of fun with that!!! I had to sell mine last year and I miss it every day. I rode it around my urban nieghborhood and the folks on some of the cul-de-sacs thought I was nuts, but it was fun.
Before you street ride it check with your insurance and get a slow moving sign for the back and then have a lot of fun.
You can also enjoy turning wrenches on it without having to tear it so far down that you have it down for very long. Have fun attacking the easy to fix leaks, and as to leaks that require engine work etc. just buy some oil and keep her full.
