Help ID finish mower
SlowCredit
Picked up an old finish mower. 5'. Deck is solid, but hubs-spindles are no good. Hinged flaps on sides and rear. 3 spindles and 2 pulleys. Gearbox seems solid. Only has wheels on back.
Anyone have an idea what this is? Or better yet, where I can find a 3 bolt spindle (5.25 center to center on holes)
Mower blades have 1.375 center hole which seems very uncommon. . .
Not having any luck finding spindles or the 1-off blade.
Thanks in advance for any info or ideas!
Slow
Pics. . .
It's definitely plan b - would like to be able to ID so I can see if I can find the blades - the ones I have are in rough shape and are just about worn out.
I might be able to find someone with a lathe and get the standoff turned down to 1" from 1-3/8. Or I guess I could put blades with a 1" hole on the drill press and widen holes to 1-3/8. . . Both of those are putting even more work into a pretty poor starting place.
Thanks for your thoughts
