help identifying a tractor
If anyone can help me - I was referred here from the "tractor talk" folks - I have recently acquired a Ford tractor - I was told that it is a 1952 8N, but the hood has the 800 series emblem. The only numbers that I can find on the engine are:
NDA 4024 B
EAF 6015 H
52P
I would like to do some work on her - but it isn't easy without knowing the year or model - can anyone help?
kelly its not a 8n with that casting number, go to your tractor and look right behind where the starter mounts to the transmission housing, there is a flat space there on the top of the bellhousing , the serial number is stamped there, you may have to scrape away a little goo to read it, post that and we'll tell you what you have probably is a 800, but the number will pin it down for sure
