Help identifying disk harrow
How do you guys like them. We bought it for food plots. Only complaint so far is you can only pull it about 9mph on road.behind truck then it starts to.wobble like something fierce. Hopefully theres a way to fix thay
The wobble is from the loose
hitch clevis, tighten it up
with bushings or what ever
will help. You can also use a
strap from the hitch pin to
the side of the disc to pull
the slack out. That is what I
do. They are an ok disc, not
the best but not the worst
either
If you also lift it just enough that blades will clear road that also helps, changes the angle of the axle, same on a drag-pull type plow.
